NebulaFlex Switch XGS1930 Series - V4.70 Patch 8 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 4,669 image  Zyxel Employee
edited November 2024 in Switch New Release
Zyxel Switch XGS1930 Series Release Note
September 2024
Firmware Version on all models
(Click hyperlink to download the firmware directly)
Zyxel XGS1930-28HP - V4.70(ABHS.8)C0
Zyxel XGS1930-28 - V4.70(ABHT.8)C0
Zyxel XGS1930-52HP - V4.70(ABHV.8)C0
Zyxel XGS1930-52 - V4.70(ABHU.8)C0
New Feature and Enhancements
1. [Standalone] Enhance security by forcing users to change the password after first login.
2. [Standalone] Support Zyxel Private MIB.
    - Hardware Monitor
    - Power Ethernet
    - Transceiver
3. [Standalone][Nebula] Expand NTP servers from 1 to 3.
Bug Fix
C=Cloud mode, S=Standalone mode
Bug fixCS
1. [eITS #240100009] Fixed memory leak issue causing packet switching failure when the switch configures a non- existent IPv6 gateway and receives Bug fix Nebula Standalone numerous unknown IPv6 packets.-V
2. [eITS #231201249] Fixed switch may reboot automatically when receiving IPv6 packets.-V
3. [eITS #230801482] Fixed an issue causing the switch to repeatedly switch from standalone mode to cloud mode leading to switch offline.V-
4. [eITS #240300246] The switch hangs when an IPv6 client roams.-V
5. [eITS #240500205] Switch hang when click PD "Reset" via Neighbor page.-V
6. [eITS #240501702] Fixed device IP address and uplink usage are not displayed correctly on Nebula.V-
7. Fix the issue where checking the IPv6 routing table on the web causes the device to crash.-V
8. [eITS #240601476] Continuously collecting the tech support file may cause the device to crash.VV
9. [eITS # 240601476] Using SNMPwalk to query the Q-Bridge MIB will return incorrect values when voice VLAN is enabled on the device.VV
Please refer to the Download Link for more details.
Zyxel Melen
  • FlamencoAssassin
    FlamencoAssassin Posts: 32 image  Freshman Member
    First Answer First Comment Friend Collector First Anniversary
    Thanks for the adding the Private MIB support. The extra SNMP data is really useful.
    I was expecting this highly anticipated update to be in the form of a V4.80 update with the revised webUI. This is based on a post made by a Zyxel rep in this community back in March.
    Is a V4.80 update still in the pipeline?
  • Zyxel_Melen
    Hi @FlamencoAssassin,
    Thanks for your input. I have let our switch product team know your voice. I will keep you posted if we have any updates.
    Zyxel Melen
  • FlamencoAssassin
    Thanks @Zyxel_Melen
    I can quote the post made by your colleague on March 18th if needed.
  • WolfgangOCG
    WolfgangOCG Posts: 1 image  Freshman Member
    I am also interested to see the 4.80 look and feel on the XGS1930 Series.
    Would be great and streamline administration.
