Trunk configuration
I have two WANs with 200MB Full each. How do I make it so that when WAN1 goes down, WAN2 goes up automatically?
Do I need to configure something in routing besides creating the trunk?
How do I create Trunk so it works this way?
I'm using the USG FLEX 200
Thanks for the information. One more thing: In my corporate network I created a routing so that the internal LAN1 leaves via WAN1. With this change in the trunk that you told me about, what would this runting look like? Do I have to delete it? Or should I do some other configuration so that it works the way I said, if WAN1 goes down, WAN2 goes up and we don't run out of internet?
Thank you very much for the help.
Yes, this way LAN1 can go out only on WAN1.
You should create another policy route for LAN1.
#1 pointing to WAN1
#2 pointing to WAN2
Both with "healthy check". So, if WAN1 is working, #1 is used. When WAN1 is down, #1 gets disabled and #2 is used.
Hi @Gel,
Change the next-hop of this policy route to the new Trunk.
Note: you need to enable and setup connectivity check in the primary interface.
What valerio_vanni mentioned is also a solution.
My preference is to use trunk to set up. It makes the policy route table cleaner. Too many rules often make it difficult for me to debug.
would it be like that? Instead of interface, put configured trunk
Would this be a second option?
Yes, trunk method is simpler than mine.
You can SNAT to outgoing interfaces, I use the other method because I have to SNAT to different addresses.
Thank you everyone for the information. Next Saturday I will make the changes and see how the network behaves. Once again thank you all very much.
I tried to configure it with trunk and it didn't work. I'm putting some images to see if I made the right configuration.
where I circled in red, is the configuration correct? Does it have to be like that?
In the routing option, in the route policy, when editing my LAN1 in nexte-rop, do I put trunk? Could it be that when WAN1 goes down, WAN2 goes up automatically?
Would this be the configuration? Thanks in advance for your attention. Thank you very much.
Did I make the correct configuration?
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
