How to exit from SSH session on GS1900-8HP?
Best Answers
Hi @zymat6816,
After investigation, we found the exit command was malfunctioning on this firmware version, that it should exit the SSH session. We will fix this in the future firmware release. You may follow this category to receive the new firmware release notification.
Zyxel Melen0 -
Hi @Cristol,
The new firmware is released. You may check on this post:
Switch GS1900 Series - V2.90 Patch 0 Firmware Release — Zyxel Community
Zyxel Melen1
Hi @zymat6816,
The "exit" is used to exit the current mode only. Currently, GS1900 does not have a command to exit the SSH session. What SSH software did you use that needs a command to exit the SSH session?
Zyxel Melen0 -
Hi.
I am using oxidized for configuration monitoring, works well for every other type of equipment that we have. It is based on Ruby.
Hi @zymat6816,
Zyxel Melen0 -
Hi, i've installed last FW (2.80) released 08/24 and this issue isn't fix … Can you Fix for the next FW release ?
On my GS1900-8HP // ZyXEL Ethernet Switch
firmware: V2.80(AAHI.0)_20240718
command 'exit' works.
Hi @Cristol,
We will fix it in the next firmware release. The current ERA is in the middle of November.
Zyxel Melen0 -
Hi @Cristol,
Zyxel Melen1 -
seems that GS1920-8HP has a similar problem … exit command does not terminate the SSH session.
Current ZyNOS version : V4.80(ABKZ.1) | 07/08/2024
Hi @zymat6816,
I use your model and firmware version but cannot reproduce your issue. What SSH terminal software are you using? I tested with Tera Term.
Zyxel Melen0 -
my intention is to include GS1920-8HP in Oxidized configuration monitoring - which has a problem with it.
To test, I made a SSH session with Putty: after a succesfull login I typed 'exit' command which made the session "inactive", but did not close the window as it normally does. As soon as I typed any key (like space) I was back in session.
Then I also made a new session from another linux box; after 'exit' command it produced unusual message:
zyxel# exit
packet_write_wait: Connection to x.x.x.x port 22: Broken pipe <IP removed>linux:~ $
- 431 Beta Program
- 2.6K Nebula
- 169 Nebula Ideas
- 113 Nebula Status and Incidents
- 6K Security
- 382 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
