Disable restrictions on VPN?
Router# show vpn-site-to-site-dynamic-restriction status
Device Restriction Status: Enable
VPN Daemon Status : Enable
there is one tunnel site to site that seems to be blocked by some sort of ban or DDOS prevention, i would like to temporarily disable the above restriction in order to check if the tunnel start to work again
Thanks for the support
Hi @phphil
To help us investigate further, could you please provide the following details:
- What model of firewall are you using?
- What is the current firmware version? Please ensure it's up to date for the best protection.
- Has the VPN tunnel worked properly before? When did this issue first occur?
- You can try temporarily disabling the security policy feature to check if the traffic is being blocked by a security policy rule. This will help us determine if the issue is related to the restriction.
Kay
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
