admin account always logged in twice, three or more times
Hi there,
I am managing about a dozen Zyxel firewalls and on all of them I got the same problem since the last firmware update, I suppose. After logging in as "admin", nearly always the "admin" shows login in twice, three times or even more. The problem is then, that I will always get kicked out of the last active messing nearly immediately. Ending one session does sometimes help, but not always.
Btw. macOS and Windows behaves the same!
Is there any way to I avoid this? I have tried changing reauth but does not help.
Many, as always, thanks for your help…
Alexander
Hi @AlexandervW ,
It appears you have multiple login sessions from the same IP address (same laptop).
To ensure all existing sessions are cleared before troubleshooting:
- Go to the Login Users tab
- Select all users
- Click Force Logout
- Log in again
- Verify that only one user session is active
Hi @AlexandervonW ,
Could you please try logging in again using a in private window or after clearing the cache in your current browser to see if the issue is resolved?
If the issue persists, could you record your screen showing the problem? This will help us better understand the issue.
Hi @AlexandervW would you kindly share which model of device you're using?
Hi all,
so, i use some USG FLEX 200, ATP 500/700 for ex. On all i have the same problem. Attached i have some screens from one USG FLEX 200 and one ATP700, after logging in on a private windows (yes, cleared cache) with Google Chrome on macOS.
Many thanks for help
Hi @AlexandervW ,
- Select all users
- Log in again
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
