revert back to 1.21 firmware
elio
elio Posts: 9  Freshman Member
Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
Best Answers
  • Sandro_ACP
    Sandro_ACP Posts: 4  Freshman Member
    You have to enable in the GUI the backup firmware via CLI like the old one end the play is done
    Search in the forum for the right command, I found it there
  • elio
    Command please?
  • elio
    Thank you PeterUK!
  • elio
    The T-Mobile cell Spot stopped working and the Top 5 Applications and Top 5 Category on Security Dashboard were greyed out after Firmware v1.30(ABWV.0) Update, but now that I went back to v1.21(ABWV.0) ALL IS GOOD.
  • Zyxel_Judy
    Zyxel_Judy Posts: 1,788  Zyxel Employee
    HI @elio ,
    Please note:
    • The Top 5 Applications data is only visible when App Patrol is enabled
    • The Top 5 Categories data is only visible when Content Filter is enabled
    We have confirmed that both App Patrol and Content Filter are displaying data correctly on our test system running firmware version 1.30. Could you please verify if both App Patrol and Content Filter are still enabled on your firewall after upgrading to version 1.30?
    If you continue to experience this issue, we can provide instructions for sharing WAN access to allow us to investigate further.
    We are not clear about your issue, and we don't believe it is related to your firewall. Could you please share more detailed symptoms and specific issues you're experiencing?
  • elio
    (Thank you, I had to restore to default then re-enter everything. now works (no static ip)
