USGFLEX 50 ip-address change
Best Answers
Hi @MattiS ,
Please see PeterUK's recommendation firstly.
If you still want to change your LAN IP addresses from 192.168.10.xxx to 192.168.100.xxx, you can follow these steps:
- Navigate to: Configuration > Network > Interface
- Select the LAN interface you want to modify (e.g., lan1)
- Update the IP address
- Adjust DHCP configuration if necessary
Zyxel_Judy
I want the LAN ip addresses to be 192.168.100.xxx. F.eg. Printer address is in the old firewall 192.168.100.200, so I want the printer to be the same address in this new Flex50.
If you have 50 devices with DHCP set for x days and you change the LAN subnet on the flex you have to reboot devices or wait x days for them to get the new IP in that subnet or change lease time to 3mins wait x days on the old lease then change the IP subnet and your devices will get a new IP in that subnet in 3 mins
I don't recommend 192.168.100.xxx if you have a modem thats on 192.168.100.1
Hi @MattiS ,
Zyxel_Judy
Hello!
Thank you, for your answer, Judy!
I did that and added a bit lower a IP Pool start address to 192.168.100.33.
However, now I see no computers in DHCP table! Why?
I can't fix any IP addresses now.
Best regards, Matti
reboot the computers
- 441 Beta Program
- 292 Service & License
