USG 20W - WLAN and WPA2-ENT Configuration
Hi all,
I've just bought a second hand USG20W (not USG20W-VPN) basically to make some test for a VPN I need to create for a small office.
Anyhow it's the first time I approach to a ZyXEL and I honestly find it a little bit difficult to use if compared with other router, and the user manual is not so clear.
I was trying to learn its settings and I've run into the wlan configuration (not PSK) following the instruction reported into the manual but I cannot figure out what's wrong. I was setting the router with a WPA2-Enterprise security mode and "Auth Method" as Authentication type.
I create new user, installed the certificate on a pc client but I'm not able to login.
Could someone help me?
Did you select WPA2-Enterprise and use Smart card to do the authentication?
I confirmed that currently the USG does not support it.0 -
Jeremylin said:Did you select WPA2-Enterprise and use Smart card to do the authentication?
I confirmed that currently the USG does not support it.Hi Jeremylin,thank you for your answer. Actually no, I've selected PEAP authentication method as suggested on the manual but it reports also to use a certificate (even self-signed) and to install it within the trusted certificates on client pc. With this configuration, the login window pops up asking for user and pwd (I've already registered a new user in the router) but it doesn't connect anyway.I'm seriously getting crazy!
@sebas80
Regarding to this case,
can I confirm the setting which you configured on USG, the radius type: Internal, Select 802.1X, Auth. Method is default.
On PC side, select WPA2-Enterprise, PEAP. Can I know where did you import certificate exactly?
Can you also private message the configuration to me? I will private message to you as well.
Charlie0
- 215 Nebula Ideas
- 569 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
