200H 1.30 - Error and crash at configuration change, reverts to 1.21
bbp
bbp Posts: 70
First Answer First Comment Friend Collector Seventh Anniversary
image  Ally Member
After upgrading to 1.30 ABWV0C0 (from 1.21 ABWV0ITS-24WK37-0909-240801054) and trying to change config, I get the error 50001
Can't reboot because console login is not possible, stuck at "Waiting for netconf server during 60 seconds" after entering the password. It remains hanging there.
After unplugging power to reboot, it will revert to 1.21
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,767
    image  Zyxel Employee
    Hi @bbp ,
    Let me provide the conclusion for this case. After updating the firmware we shared, your 200H successfully booted into the new firmware, and the configuration conversion worked properly. So far, everything appears to be working correctly.
    Zyxel_Judy
  • Asgatlat
    Asgatlat Posts: 138
    First Comment Friend Collector Ninth Anniversary
    image  Ally Member
    as @PeterUK report, see this :
    seems you have to config your flex config file from scratch
  • Zyxel_Judy
    Hi @bbp ,
    To help us investigate further, could you please provide the following information:
    Go to Maintenance > Diagnostics > System Logs and download the boot-config-error file.
    Go to Maintenance > Firmware/File Manager > Configuration File and download the startup configuration file that works with firmware version 1.21. We will apply it to our USGFLEX200H, upgrade to version 1.30, and observe the issue to determine which configuration settings are incompatible with version 1.30.
    The files can be sent via the private message by clicking to my account > Message
    Zyxel_Judy
  • Zyxel_Judy
    Hi @bbp ,
    Zyxel_Judy
