Playboy.com bypassing content filter
RickyC
RickyC Posts: 14 image  Freshman Member
Other popular? sites of this type I tried are blocked. No matter what I do, Playboy.com is not blocked and we certainly don't have an exception for them. The test url successfully identifies as Pornography, but still the site is not filtered. Maybe its a bug?
    PeterUK Posts: 4,415 image  Guru Member
    edited October 2024
    What model firewall are you using? Is firmware upto date?
    is the client using a VPN or proxy?
    Block UDP 443
    run SSH or by webconsole
    debug content-filter https-domain-filter cache flush
  • electsystech
    electsystech Posts: 60 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    You'll need to setup a DNS content policy as well.
