Can anyone explain this router log to me please? What are upnp subscribers?
I had UPNP enabled, disabled it now. This log is from the time when UPNP was enabled.
What does this mean?
daemon err upnp miniupnpd: upnpevents_processfds: 0x8e3368, remove subscriber uuid:5b55dc20-7cd6-4c41-9b2a-1e52d96751a3 after an ERROR cb:
http://xxx:2869/upnp/eventing/zzuvnaqnbz
daemon warning upnp miniupnpd: upnp_event_process_notify: connect(xxx:2869): Connection timed out
daemon debug dhcpc udhcpc: Sending discover...
daemon err upnp miniupnpd: upnpevents_processfds: 0x8e3368, remove subscriber uuid:2a1ede6f-2303-46c2-baed-88048fbbe3ad after an ERROR cb:
http://xxx:2869/upnp/eventing/immidyyhya
xxx represents my IP.
What are these subcribers? There were two. Thanks
Not sure, but what do these subcsribers mean? Something harmless or harmful? Thanks
The answer should be somewhat easy to deduce, at least if you are familiar with the layout of logs in general. Taking your time to do a Google search (or any other search engine), it should provide you with some basic information to make it easier to start reading the manual and learn more about the features.
I performed a Google search using the following part of your log sample:
miniupnpd: upnpevents_processfds: 0x8e3368, remove subscriber uuid:Here is a link to the Google search:
I will post a couple of links below to sites where this type of log has been discussed already. It is recommended that you have got a modicum of knowledge about UPnP, at least knowing just a little bit about why they are used in the first place (as suggested in one of the linked posts).
[Github]
The Github page is easy to read and contains the shortest explanation:
[miniupnp commented on May 18, 2018]one client requested event notification (through the SUBSCRIBE HTTP request)and connection to the notification http url timed out (the machine is probably turned-off :)
[Reddit]
More dialog, maybe less clear explanation, unless you have got some previous UPnP knowledge.
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
