Add Content filter Exception List
Swyft
Swyft Posts: 3 image  ZCNE Certified
First Comment Friend Collector Second Anniversary ZCNE Nebula Level 1 Certification - 2019
edited April 2021 in Security
Anyone experience the below message when trying to add IP address to content filter exception list?
CLI Number: 13
Error Number: -43040
Error Message: 'Join member into address-object group has failed.'
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @Swyft
    Can I know did you add the IP address to the group whose address type is FQDN or GEOGRAPHY?
    The IP base(Host, subnet,range…), Geography and FQDN concurrent can not belong in the same Address group.
    Charlie
  • Swyft
    edited March 2019
    Thank you for your response. No i have not created any groups, I am just adding 1 IP address to the exception list for all browsing, I tried with setup as DHCP and if i add client MAC address, I've done multiple of these firewalls in the same way and its working fine, just this particular one
    Regards
  • Zyxel_Charlie
    @Swyft
    Regarding to this case,
    can you share more details of "I tried with setup as DHCP and if i add client MAC address"?~Do you mean the  MAC address on IP/MAC binding? and what's particular one of you mentioned?
    Also, can you private message the configuration for check further?
    Charlie
  • Swyft
    My apologies for the delay. So the DHCP is enabled and if you go into the setup you can include IP addresses to the exception list. Yes i do mean ip/mac binding. The particular one mention is the Zyxel USG 60 firewall. i have attached the screens i spoke about
    Regards
  • Zyxel_Charlie
    @Swyft
    I can move the batch of IP address to exception-list without any issue.
    Can I know the exactly did you process?
    I would like to check your configuration, so please private message it for check further.
    Charlie
