USG 20W - WLAN and WPA2-ENT Configuration
sebas80
sebas80 Posts: 2 image  Freshman Member
Zyxel Certified Network Administrator - Switch First Comment Fifth Anniversary
edited April 2021 in Security
Hi all,
I've just bought a second hand USG20W (not USG20W-VPN) basically to make some test for a VPN I need to create for a small office.
Anyhow it's the first time I approach to a ZyXEL and I honestly find it a little bit difficult to use if compared with other router, and the user manual is not so clear.
I was trying to learn its settings and I've run into the wlan configuration (not PSK) following the instruction reported into the manual but I cannot figure out what's wrong. I was setting the router with a WPA2-Enterprise security mode and "Auth Method" as Authentication type.
I create new user, installed the certificate on a pc client but I'm not able to login.
Could someone help me?
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    Did you select WPA2-Enterprise and use Smart card to do the authentication?
    I confirmed that currently the USG does not support it.
  • sebas80
    Hi Jeremylin,
    thank you for your answer. Actually no, I've selected PEAP authentication method as suggested on the manual but it reports also to use a certificate (even self-signed) and to install it within the trusted certificates on client pc. With this configuration, the login window pops up asking for user and pwd (I've already registered a new user in the router) but it doesn't connect anyway.
    I'm seriously getting crazy!
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @sebas80
    Regarding to this case,
    can I confirm the setting which you configured on USG, the radius type: Internal, Select 802.1X, Auth. Method is default.
    On PC side, select WPA2-Enterprise, PEAP. Can I know where did you import certificate exactly?
    Can you also private message the configuration to me? I will private message to you as well.
    Charlie
