Zywall 110 extrange behavior with subdomain
jaalsa
jaalsa Posts: 2 image  Freshman Member
The firewall is running V4.73(AAAA.2).
We have a domain (example.es), with the appropiate DNS entries configured at our registrar for our website:
IN A example.es x.x.x.x
IN A www.example.es x.x.x.x
The issue is that in the office, we have some virtual machines (running behind a proxy) for which we want to use subdomains of the company's domain: vm1.dev.example.es, and so on.
So we created CNAMES in the Zywall DNS configuration pointing to the local A entry for the server where those vms are:
vm1.dev.example.es CNAME devsrv.company.local
(The firewall domain is configured as example.local)
These CNAMES are working great, but they are, for some reasong, rendering the zywall unable to resolve "example.es". If the delete the CNAME, the zywall is then again able to resolve "example.es".
Some pictures are attached with the actual configuration, real domain and DNS queries results made from the zywall.
CNAME and dns lookup with cname:
It's like the zywall is stating that iself is the authoritative server for the "example.es" (aa flag) ant it's saying it doesn't exist. I don't understand why.
No CNAME and dns query from the zywall (no aa for example.es this time):
Thanks!
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @jaalsa ,
    System will have such DNS zone file when you have kind of CNAME record, so you are right firewall act as NS itself this time. So, you can try to add an A record for "aptica.es" A 79.139.120.30 in GUI as workaround.
    Please be aware that the Zywall 110 model has reached its End of Life (EOL) status, which means our support for this model will be limited. For information on alternative options, you also can refer to the available models:
    Next-Gen Firewall | Zyxel Networks
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @jaalsa ,
    Zyxel_Judy
    Untitled Image
  • jaalsa
    edited November 2024
    Thank you very much.
    I have tested too removing the CNAME and creating a
    x.dev.aptica.es IN A internal_ip
    And the same happens, the firewall puts itself as authoritative over aptica.es.
    We have implemented the suggested workaround successfully. Thanks.
    I'd like to ask: is this because of the zywall's dns implementation? We are considering upgrading the zywall to a newer one, is this issue resolved on them?
    Thanks!
  • Zyxel_Judy
    Hi @jaalsa ,
    This is the current DNS implementation across all Zyxel firewalls. Please use our suggested solution to meet your requirements.
    Zyxel_Judy
    Untitled Image
