Connect to lan from external lan
Gru_Ma
Gru_Ma Posts: 15 image  Freshman Member
Hello
I have this scenario:
A lan with 192.168.1.x in this lan i have a zyxel USG Flex200 that manage another lan with 192.168.0.x. So from external client i can connect by ssl vpn to firewall and the 192.168.0.x lan, but i need also that 1 pc from 192.168.1.x can connet to 192.168.0.x. If i use the zywall secure extender not work with error:
2024/11/04 18:41:52 ][SecuExtender Helper] Request(88): REMOVE 0/2248255680 22 4294967295 4294967295
[ 2024/11/04 18:41:52 ][SecuExtender Helper] Remove Routing
[ 2024/11/04 18:41:52 ][SecuExtender Helper] Remove prioritize routing
[ 2024/11/04 18:41:52 ][SecuExtender Helper] Get netsh path = powershell
[ 2024/11/04 18:41:52 ][SecuExtender Helper] ia is null
[ 2024/11/04 18:41:52 ][SecuExtender Helper] Failed to read from client(2): 109, 0
[ 2024/11/04 18:41:52 ][SecuExtender Helper] Start to Disconnect pipe...
[ 2024/11/04 18:41:52 ][SecuExtender Helper] Shutting down a pipe connection instance...
[ 2024/11/04 18:41:52 ][SecuExtender Helper] ==============================
[ 2024/11/04 18:54:06 ][SecuExtender Helper] Request(88): REMOVE 0/2248255680 22 4294967295 4294967295
[ 2024/11/04 18:54:06 ][SecuExtender Helper] Remove Routing
[ 2024/11/04 18:54:06 ][SecuExtender Helper] Remove prioritize routing
[ 2024/11/04 18:54:06 ][SecuExtender Helper] Get netsh path = powershell
[ 2024/11/04 18:54:06 ][SecuExtender Helper] ia is null
[ 2024/11/04 18:54:06 ][SecuExtender Helper] Failed to read from client(2): 109, 0
[ 2024/11/04 18:54:06 ][SecuExtender Helper] Start to Disconnect pipe...
[ 2024/11/04 18:54:06 ][SecuExtender Helper] Shutting down a pipe connection instance...
[ 2024/11/04 18:54:06 ][SecuExtender Helper] ==============================
