starlink
Aballo
Aballo Posts: 20 image  Freshman Member
Does anyone did a VPN over starlink ?
We've got 2 USG Flex 200, ISP fiber Router on one side, Starlink router in bypass mode at the other side…
an idea ?
Many thank's
L.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @Aballo,
    I think you should ensure which IP policy your Starlink is using. If it is using the default IP policy, then you cannot build a site-to-site VPN tunnel since it is CGNAT. You can only build the site-to-site VPN tunnel if it using public IP.
    Zyxel Melen
  • Aballo
    Is this something that can be changed?
  • Aballo
  • Zyxel_Melen
    Hi @Aballo,
    Please check with Starlink about the Starlink IP policy.
    Zyxel Melen
