VPN 100
I have an question about the VPN 100 support. Is this device end of life. When i look at the status, i can see on the status page from zyxel, the end of vulnerability support is 30-09-2023. But the latest firmware is from february 2024. Is this device EOL or not?
For example when i look for the zywall 110 (which i know its EOL), on the status page the vulnerability support is till 31-12-2022, and the RMA is till 2027. The RMA for the VPN100 is till 2025.
Especially because of the firmware update of february im not sure about the status.
yours dennis
Hi @Dpj
The VPN100 firmware update (5.37(ABFV.2)) from February 2024 was released to address specific critical CVEs, even though the end of vulnerability support date for this device was September 30, 2023. After this date, Zyxel typically does not release security fixes or vulnerability updates. However, we do make exceptions for widespread critical vulnerabilities, which is why this firmware update was issued.
As of now, the VPN100's end of support date is set for March 31, 2025. This means while general security patches have ended, any essential maintenance updates for critical vulnerabilities may still be provided.
Please also note that the "End of RMA & Tech Support" date may vary depending on the region. For global (except US and Taiwan) EOL information, you can check this page: .
Hope this clarifies things!
Kay
Yes is EOL I did wish Zyxel support it for as long as the FLEX models
but why still firmware update then in 2024? do you know that?
Due to vulnerabilities and Exposures they did one more patch for them models
So are they going to issue another patch for the last vulnerabilities?
Not likely 😒
Hi @Dpj
Kay
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
