Tranfer Config from Zyxel310 to USGFlex700
ProgThrSup
ProgThrSup Posts: 2 image  Freshman Member
edited November 2024 in Security
We try to transfer config file from Zyxel310 to USGFlex700 following the description
https://support.zyxel.eu/hc/en-us/articles/11410109118226-Zyxel-Firewall-Convert-Tool-Troubleshoot-Configuration-Upload
no sucess at all
the code modivied by the Convert-Tool get totaly rechected by Flex700 nearly, the log file says to nearly every line "Ignore startup-config_converted-83657.conf:####"
comparing a config file from Flex700 with a modivied one shows that
Flex700 use totaly different commands (no more ! instead "/ ogject …"
is a migration of setting still posible?
we try to transfer the entcrypted password by replacing the one in Flex700.conf with the one from modivied Zyxcel310.conf but this also fail with "Unsatisfied pattern"
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    HI @Prog,
    Could you please send me the original configuration file of your USG310 via private message? We'll review it and attempt to apply it to the USG FLEX 700, then share the results with you.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    HI @Prog,
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @ProgThrSup ,
    Regarding your failed conversion from USG310 to USG FLEX 700, we believe the issue may be related to a version compatibility gap in V4.60.
    We have manually converted the configuration file to the latest version (5.39) and sent for you. Please check the Community inbox to get the configuration file.
    Zyxel_Judy
    Untitled Image
