Migrate USG100 to USG FLEX 200H
Good morning,
I should replace an old USG100 firewall with a USG FLEX 200H. Is it possible to migrate the configuration without having to do everything manually? I saw that there is a tool but I think it is not compatible with old models like USG100.
Thank you
Hi @MatteoEuro
We’re happy to inform you that we plan to release a new configuration converter by the end of 2024. This tool will support the migration of configurations from ZLD firewalls to uOS firewalls.
Currently, the only option for migrating configurations from the USG100 to the USG FLEX 200H is to manually refer to the ZLD configuration through the Web-GUI or the configuration file content in order to set up the new uOS configuration.
Kay
indeed, the migration tool seems to not support the H model
maybe because of the new uOS ?
Hi @MatteoEuro
Kay
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 632 USG FLEX H Series
- 354 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 300 Service & License
- 492 News and Release
- 109 Security Highlight
