What's the entry limit for static IP on USG Flex series?
Hello everyone,
I'm currently experiencing limitations with our Zyxel USG50, which we've been using for several years. My main concern is the DHCP static IP configuration, which is restricted to only 96 manual IP entries.
This limitation is problematic as our Institute operates numerous probes that require precise firewall targeting. Given that we've recently received funding for hardware improvements, I'm considering upgrading to either a USG Flex 200 or 500 model.
However, I've been unable to find any documentation, either in the manual or online, regarding the static IP entry limits for these models. I would greatly appreciate if any USG Flex 200 owners could share information about the maximum number of manual IP/MAC bindings possible in addition to the DHCP configuration.
Thank you for your attention to this matter.
Hi @IPL ,
The entry limit for static IP on the USG FLEX 200 is 256, while on the USG FLEX 500 it is 512. This information can be found in the USG FLEX Series User Guide on page 1231.
Zyxel_Judy
Hi @IPL ,
Zyxel_Judy
Hi @Zyxel_Judy, thank you very much for your quick and precise answer.
- 603 USG FLEX H Series
- 481 News and Release
