GS1900-24 Rev A1 firmware
Hi @trumee
You can download the latest firmware for the GS1900-24 from our .
The current firmware version available is V2.90(AAHL.0).
Kay
Hi @trumee
Kay
@zyxel_kay The firmware you have linked is for C0 revision. My switch is A1 revision. Can I use a C0 revision firmware with an A1 switch?
Hi @trumee
The "C0" label refers to the official version of the firmware patch and isn't specific to your switch model. You can go ahead and install the latest firmware version, V2.90(AAHL.0), on your GS1900-24 switch.
Kay
Ah, good to know. I also have a GS1900-16 again running Revision 1 of V2.60(AAHJ.2). Can i upgrade it to Revision C0 2.90(AAHJ.0)?
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
