GS1900-8HP missing MIB OIDs
I have GS1900-8HP with firmware V2.40(AAHI.1)_20180705
I would like to be able to swith PoE from port on and off. In GS1910-24HP it is possible using OID-.1.3.6.1.2.1.105.1.1.1.3, but is it in this? This OID can be found from MIB, but no data is found, and it is not listed in snmpwalk.
Is is possible to control GS1900-8HP PoE ports via SNMP?
Hi @Dathril
Welcome to the Zyxel Community!
Unfortunately GS1900-8HP doesn't support POE on/off via SNMP given the fact it's our entry level switch.
You may have to switch PoE on/off via Web-GUI.
In addition, you may consider our higher level switch series, such as GS2210-8HP which can support the feature you need.
Sincerely,
Zyxel_Lucious0 -
Hi @Dathril
By the way, you may also consider our GS1920v2-8HP. It is our web-managed switch series which partially supports SNMP OIDs, including the desired feature.
For a switch fully supports SNMP, our GS2210 series would be an excellent choice. Better yet, it can support CLI console management.
Zyxel_Lucious
- 603 USG FLEX H Series
- 481 News and Release
