multiple SSL connections to the same user
I have 2 inside networks: Lan1 and Lan2, I need SSL VPN for both, it works fine when 1 user only has access to 1 network, but if the user is a member of both networks, you do not get the option to choose lan1 or lan2 and trying the connection, the user has access to one but not the other
@PerBorup
Can you check that the Lan1 and Lan2 subnet are selected to "Selected Address Objects", the SSL Client permits to access both networks.
Charlie0 -
thanks i had made 2 SSL tunnels with each separate inside network and the same user on both
@PerBorup
Does the TEKNIK profile include the both networks ? and you only still can access one network?
If you want "Christian" this account can access Lan1 and Lan2 networks, you need to include both networks in one profile.(TEKNIK profile)
Charlie
- 588 USG FLEX H Series
- 476 News and Release
