USG20W-VPN Session Monitor Traffic from Server "Wiz_SSL_VPN" No VPN Defined after RESET
After upgrading to 5.39, and performing Factory RESET on Router, I had to rebuild Client's configuration per Zyxel Support recommendation
New configuration (after factory RESET) has no VPN defined, After rebuilding Client's Router manually, I'm seeing a lot of Traffic when I view "Session Monitor" from the Server IP, reference "Wiz_SSL_VPN" service.
How can there be VPN traffic to these Public IPs, when no VPN has been defined
See Attached Graphic.
Router was previously Attacked before updating 5.39 with unauthorized Userers Defined.
Hi @SierraTech,
Please help us clarify:
- Are the admin's password still the same as before? If yes, the hacker might use the same credentials to access the firewall and create the VPN configuration. In addition, since the VPN name is Wiz_SSL_VPN, the hacker might be able to access the firewall's Web GUI because only Web GUI supports wizard.
- If the answer above is yes, please remove the configuration or factory default again and rebuild the firewall configuration with the new admin's password/credentials.
Zyxel Melen0 -
Thanks for the question. I took the router completely offline and updated offsite in my home office with no Internet. I uploaded 5.39 and performed factory reset (reset button about 15 seconds or longer took a while). While keeping WAN unconnected I changed my password, and started rebuilding configuration again.
I deployed it yesterday and still seeing suspicious traffic even though WAN access to configure router is disabled and I added geo blocks on both WAN and LAN.
The internet stops working about 3 hours after reconnecting, due to traffic overloading from what I can tell, and I have to reboot the router again.
Hi @SierraTech,
Thanks for your update. I will send you a message requesting a remote PC to check this issue.
Zyxel Melen0 -
Thank you, I will look for it. Once I connect with RDp after reboot, I can stay connected but the traffic is so overwhelming, I have to run over the office and reboot both the router and modem, to return Internet access (last between 1.5 and 3 hours).I appreciate the assistance! It’s like factory reset didn’t complete.
- 217 Nebula Ideas
- 574 USG FLEX H Series
- 297 Service & License
- 472 News and Release
