ROUTING
LMitc
LMitc Posts: 13  Freshman Member
Good morning,
I have an ATP200 with a vlan/dmz to which I connected a NAS that must be reached on the external IPs of the two WANs for the services on ports 80 443 and 10001, I created the NAT rules and the security policies I needed, from outside it works correctly! If I try to reach the device on one of the public addresses of the WANs connected with a PC from the lan or the vlan, it is unreachable.
Which rule should I create?
«1
    PeterUK Posts: 3,995  Guru Member
    Sounds like NAT loopback? make sure its enabled for your NAT rule.
    You then need a policy rule from LAN1 to DMZ
  • LMitc
    loopback is active
    i create policy, but not found internal
    check logs for blocked traffic
  • LMitc
    I have no blocks in the log regarding this route
    Disable the firewall for a quick check.
    So to be clear you go from LAN2 to the WAN IP to loopback to DS1618v IP?
  • LMitc
    Do you mean disable security policies? It doesn't work anyway...
    edited November 2024
    Does your ATP get the WAN IP's not rfc1918 IP's?
  • LMitc
    My addresses are all public static
    WAN2
    WAN1_PPP
    WAN1
    port 10001 on these IPs is reachable without restrictions for testing
    I'm not sure why you can't loopback then sorry
    You can do a packet capture on the interface DMZ as you try connecting to it by WAN IP from LAN to see if its getting to the NAS
  • LMitc
    I have enabled packet cutting for DMZ
    I then tried to access the NAS from the LAN from the WAN with its two IP
    Screenshot 2024-11-19 alle 23.34.58.png Screenshot 2024-11-19 alle 23.35.10.png
    But the firewall doesn't even generate log files
