Next Hop: VPN Tunnel Flex 100H
amateur_netops
amateur_netops Posts: 12  Freshman Member
edited October 2024 in Security
I am looking to upgrade my home VPNs from Zywall USG 110s to Flex XXXH(P) - I had upgraded one of them this summer - and realized that I could not define a VPN tunnel as a next hop. Zyxel Customer Service then replied to a message that would be a feature supported in the October firmware - it does not seem to exist in the 1.3 release however either. What I am trying to support is this: I have SSIDs (VLANS) in each home that represent a specific country - so SSID.NET would be US, SSID.AT for Austria, SSID.ID for Indonesia and SSID.IN for India. So if you were for example on SSID.AT in a home in the US, the traffic would be routed to a home in Austria and go on the public internet there. Truthfully mainly used for streaming content - but it's sometimes useful for specific country content.
Questions:
1, Did I miss anything in 1.3 (running on a Flex 100H) where that feature has been added.
2, If it has been dropped from 1.3 - when is it coming now?
3, Is there another way to accomplish what I am trying to do
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,268  Zyxel Employee
    Hi @amateur_netops
    Due to changes in the product roadmap, there was no feature enabling VPN tunnels as next-hop with firmware version 1.30 for H series firewalls.
    We are still evaluating this feature. When it becomes available, we will make an official announcement in the Firewall News & Releases section. Please follow this section to stay updated on new features and enhancements.
    For your scenario, we can suggest following the guide to configure Site-to-Site VPN between ZLD (USG, USG FLEX) and uOS (USG FLEX H) using Route-based VPN.
    Please let us know if we can be of any help.
    Zyxel_Judy
  • amateur_netops
    Hmm - disappointing that the feature has not been added as previously stated by Zyxel support - it is the only reason I bought another Flex H for another home.
    I don't see how the guide helps me since traffic to the internet will not go through the tunnel.
    Here is a simplified scenario:
    Site A has two networks - 192.168.100.X and 192.168.101.X
    Site B has two networks - 192.168.110.X and 192.168.111.X
    Devices on 192.168.100.X and 192.168.110.X need to communicate together - OK - Site to Site deals with that just fine
    Devices on 192.168.101.X should use the public internet on Site B
    Devices on 192.168.111.X should use the public internet on Site A
    A site to site doesn't do much here - in my old configuration - all traffic from 192.168.101.X would be sent to 192.168.110.X - where all traffic from 101.X would go to WAN - and all traffic for 101.X would be forced back into the VPN from 110.X-101.X
    How does a site to site without an ability to force traffic there help me?
  • Zyxel_Judy
    Hi @amateur_netops ,
    As of now, you can establish a Route-based VPN (VTI) by following the instructions in the article above. Once configured, follow these steps to add policy routes to adapt your requirement.
    Site A: LAN = 192.168.101.X/24
    Need to create one policy route to force redirect traffic to site B from site A.
    src = 192.168.101.X
    dst = any
    next hop = VPN => Choose Tunnel name
    Site B: LAN = 192.168.111.x/24
    Need to create two policy routes:
    Policy route 1: is for SNAT to Internet when the source is site A subnet 101.X
    src=192.168.101.X
    dst = any
    next hop = WAN1 or WAN2
    SNAT = outgoing interface
    Policy route 2: is for routing back the subnet 101.x traffic from Internet.
    src = any
    dst = 192.168.101.X
    next hop= VPN => Choose Tunnel name
    SNAT => None
    Zyxel_Judy
  • amateur_netops
    But there is no next hop=VPN - that was what I as whining about and was initially told we would get in October.
    The options on the Flex are: Auto, Interface, gateway,, gateway-ip and trunk - VPN is not an option
  • Zyxel_Judy
    As we mentioned above, you can establish a Route-based VPN (VTI) by following the instructions in this article, and then you can see the VPN option in Interface next-hop type.
    Here is the screenshot of the H series:
    Zyxel_Judy
  • amateur_netops
    OK - got this to work - thank you. I had to delete the other connections between other subnets on those sites and also manually route them. Then I had to change MTU to 1300 on the WAN port since tracert would work but http or https did not - somewhat odd - and a little slower than I would have expected. But got it working now
  • amateur_netops
    Oh - is there a way to rename those vti-wizzard something things to something more meaningful. Will be a pain to keep track if I have several
  • Zyxel_Judy
    Under the current uOS design, VTI interface names cannot be modified. However, we have implemented a description field in both the interface and static route configurations that allows users to add custom identifiers for easier reference.
    Zyxel_Judy
