ROUTING
Good morning,
I have an ATP200 with a vlan/dmz to which I connected a NAS that must be reached on the external IPs of the two WANs for the services on ports 80 443 and 10001, I created the NAT rules and the security policies I needed, from outside it works correctly! If I try to reach the device on one of the public addresses of the WANs connected with a PC from the lan or the vlan, it is unreachable.
Which rule should I create?
Sounds like NAT loopback? make sure its enabled for your NAT rule.
You then need a policy rule from LAN1 to DMZ
loopback is active
i create policy, but not found internal
check logs for blocked traffic
I have no blocks in the log regarding this route
Disable the firewall for a quick check.
So to be clear you go from LAN2 to the WAN IP to loopback to DS1618v IP?
Do you mean disable security policies? It doesn't work anyway...
Does your ATP get the WAN IP's not rfc1918 IP's?
My addresses are all public static
WAN2
WAN1_PPP
WAN1
port 10001 on these IPs is reachable without restrictions for testing0 -
I'm not sure why you can't loopback then sorry
You can do a packet capture on the interface DMZ as you try connecting to it by WAN IP from LAN to see if its getting to the NAS
I have enabled packet cutting for DMZ
I then tried to access the NAS from the LAN from the WAN with its two IP
But the firewall doesn't even generate log files
- 415 Beta Program
- 2.4K Nebula
- 144 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.6K Security
- 237 USG FLEX H Series
- 267 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.3K Consumer Product
- 247 Service & License
- 383 News and Release
- 83 Security Advisories
- 29 Education Center
- 3.2K FAQ
- 71 Security Highlight
