USG FLEX H Series - V1.30Patch 1 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 4,669 image  Zyxel Employee
Zywall USG FLEX H Series Release Note
November 2024
Firmware Version on all models
  • Please use the cloud firmware upgrade function to upgrade USG FLEX H Series
USG FLEX H SeriesFirmware Version
FLEX100HV1.30(ABXF.1)C0
FLEX100HPV1.30(ACII.1)C0
FLEX200HV1.30(ABWV.1)C0
FLEX200HPV1.30(ABXE.1)C0
FLEX500HV1.30(ABZH.1)C0
FLEX700HV1.30(ABZI.1)C0
Note1: For the initial installation of the USG FLEX H Series firewall, please using the firmware wizard to upgrade to uOS 1.08 Patch 1 firmware first, and then proceed with the upgrade to uOS1.10 firmware. The device becomes unreachable if you upgrade USG FLEX H directly from the factory default version to 1.10 P1 or later firmware version directly.
Note 2: If you are using a date code firmware, please contact @Zyxel_Melen to get the firmware file and upgrade via local upload.
New Feature and Enhancements
N/A
Bug Fix
1. [Bug Fix][eITS#241001229, 241001349, 241001408, 241001709] Unable to upgrade the device from 1.21 to 1.30. It failed to apply configuration file and roll back to the original partition 1.21.
2. [Bug Fix][eITS#241001734] Upgrade firmware to 1.21 to 1.30 firmware the system will going as expected. But after reboot firewall manually, the configuration will become to system default.
3. [Bug Fix][eITS#241001817] Geo DB back to default signature after rebooted.
Please refer to the Download Link for more details.
Zyxel Melen
  • Jeremlvt
    Jeremlvt Posts: 1 image  Freshman Member
    edited November 2024
  • Itruz
    Itruz Posts: 1 image  Freshman Member
    hi @Zyxel_Melen,
    half of my site to site VPN drop connexion after the upgrade. it was the same issue after patch 0 on v1.30.
    i have a usg flex 700h. this is not a problem on remote usg flex 200 device because Von work we'll between different remote device.
    Did you change anything during the update ?
    Edit : After recreating manually every VPN connexion from both side, everything look fine. Problably due to secondary remote IP adress removal on every gateway.
