USG FLEX H Series - V1.30Patch 1 Firmware Release
Zywall USG FLEX H Series Release Note
November 2024
Firmware Version on all models
- Please use the cloud firmware upgrade function to upgrade USG FLEX H Series
| USG FLEX H Series | Firmware Version |
| FLEX100H | V1.30(ABXF.1)C0 |
| FLEX100HP | V1.30(ACII.1)C0 |
| FLEX200H | V1.30(ABWV.1)C0 |
| FLEX200HP | V1.30(ABXE.1)C0 |
| FLEX500H | V1.30(ABZH.1)C0 |
| FLEX700H | V1.30(ABZI.1)C0 |
Note 2: If you are using a date code firmware, please contact @Zyxel_Melen to get the firmware file and upgrade via local upload.
New Feature and Enhancements
N/ABug Fix
1. [Bug Fix][eITS#241001229, 241001349, 241001408, 241001709] Unable to upgrade the device from 1.21 to 1.30. It failed to apply configuration file and roll back to the original partition 1.21.
2. [Bug Fix][eITS#241001734] Upgrade firmware to 1.21 to 1.30 firmware the system will going as expected. But after reboot firewall manually, the configuration will become to system default.
3. [Bug Fix][eITS#241001817] Geo DB back to default signature after rebooted.
Please refer to the Download Link for more details.
hi @Zyxel_Melen,
half of my site to site VPN drop connexion after the upgrade. it was the same issue after patch 0 on v1.30.
i have a usg flex 700h. this is not a problem on remote usg flex 200 device because Von work we'll between different remote device.
Did you change anything during the update ?
Edit : After recreating manually every VPN connexion from both side, everything look fine. Problably due to secondary remote IP adress removal on every gateway.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
