VPN100 and FW 5.39 availability
Franz94370
Franz94370 Posts: 9 image  Freshman Member
Do you know when we will have the updated firmware 5.39 for the VPN100 series ?
I am facing modifications in safety policy and creation of users by hackers.
I have removed the modifications but what can you suggest ?
Regards
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,273 image  Zyxel Employee
    Dear @Franz94370,
    Since VPN100 has ended vulnerability support, it won't have the new firmware. Here are some suggestions:
    1. Please consider migrating your VPN100 to the USG FLEX/USG FLEX H series.
    2. Please factory default your VPN100. You may restore your previous configuration after reset, but need to do:
      1. Change the administrator's password.
      2. Do not allow WAN to ZyWALL access. If you need to allow it, please add some limitations like only specific IP addresses can access the firewall, and the administrators enable 2FA.
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Dear @Franz94370,
    Hope it helps.
    Zyxel Melen
