SSL VPN working on FLEX 100H?
SoftSol
SoftSol Posts: 8  Freshman Member
Does anyone have the SSL VPN working on a FLEX 100H? I have 2 FLEX 100H routers and to one connection is made, but no IP address is given, The other on only gives Connection Timeouts. I don't see any blockage in the Firewall. Zyxel tested it and say's it works, but not here, nor at a customer, OpenVPN on several laptops, on several Internet connections, nothing works. Otherwise I have to buy other routers and recycle my Zyxel stock :-(
    PeterUK Posts: 3,799  Guru Member
    edited November 2024 Answer ✓
    I have the SSL VPN working fine on FLEX200H
    Maybe the pool IP is conflicting?
  • SoftSol
    PeterUK, that is the solution for the Flex 100H I could connect to. Why the pool address is conflicting I have to research, but my customer can login and work from home. Thank you, You saved my day :-)
    Now I can examine why the other router still gives Connection Timeouts.
