ROUTING
Sorry, I had never used the tool, I tried again and performed the procedure correctly:
activate the capture with the correct IP and PORT settings
launch the https request from the LAN machine to the two external IP
stop the capture.
Download and read the .cap filesthe file is empty
Did you click to stop the capture ?
Yes yes of course, otherwise the firewall does not generate the files to download if the capture is not stopped
All I can tell you is use tcping64.exe
and keep trying
- 602 USG FLEX H Series
- 480 News and Release
