Network/NAT
noc_aba
noc_aba Posts: 37 image  Freshman Member
I have a working IPSEC VPN between site1 and site2, so that lan1 and lan2 can communicate.
I would like to map a public IP of site1 to a host of lan2.
Setting up a virtual server from publicIPsite1 to site2hostIP and adding a route to site2hostIP via the VPN tunnel doesn't work.
I suppose because the VPN tunnel allow traffic just between the lan1 and lan2 IP network.
So I've searched a way to snat the external IP accessing the publicIPsite1, but didnt' find anything.
Is there a solution ?
many thanks
Paolo
  • noc_aba
    forgot to say I'm on a ATP500 vith fw 5.39 patch1
    PeterUK Posts: 4,416 image  Guru Member
    Was able to do that here
    Connecting client for port 5126 > WANIP Zywall 110 > site to site > USG40 > host for port 5126
    Zywall 110
    LAN2 192.168.138.0/28
    site to site
    local policy 192.168.138.0/28
    remote policy 192.168.255.64/28
    NAT
    incoming WAN
    external IP WAN
    internal IP 192.168.255.66
    port 5126
    Routing
    incoming tunnel
    next hop WAN
    SNAT outgoing-interface
    incoming any
    destination 192.168.255.64/28
    next hop VPN tunnel
    USG40
    VLAN48 192.168.255.64/28
    site to site
    local policy 192.168.255.64/28
    remote policy 192.168.138.0/28
    Routing
    incoming VLAN48
    next hop VPN tunnel
  • noc_aba
    Hi, thanks, I tried your configuration but it didn't work.
    The only difference, respect to what I did before you answer, is your policy route:
    incoming tunnel
    next hop WAN
    I suppose that by tunnel you mean the tunnel between USG110 and USG40, but what I think I need is to SNAT the IP accessing the WAN IP of the USG110, so that the internal IP masquerading it can reach the host behind the USG40, going through the tunnel.
    In your configuration you snat what's coming from the tunnel while the problem is before, to go into the tunnel, IMHO.
    In any case thanks for your kinf contribution
    Paolo
    that why you do routing
    incoming any
    next hop VPN tunnel
    so that the NAT rule for 192.168.255.66 routes down the tunnel
  • noc_aba
    many thanks.
    The remote firewall, not under our control, didn't have the route policy to use the tunnel for any destinationwhen the source was the remote host.
    Added that route it works
    Paolo
