schedule on policy seems not working
Asgatlat
Asgatlat Posts: 115  Ally Member
First Comment Friend Collector Seventh Anniversary
hello,
with our USG FLex 200H (FW 1.30 patch 1), we use a policy to block streaming websites and Facebook during working hours
i created FQDN objet for websites and a schedule for working hours
the policy works but websites still blocked during lunch break
if i disable the policy rule, i get access to these websites
this configuration worked on our old Zywall 110.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,716  Zyxel Employee
    Hi @Asgatlat,
    Since the schedule day time setting is start from what time on which weekday to what time on which weekday, please reference the below screenshot to configure:
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Asgatlat,
    This could be because the schedule configuration on the USG FLEX H series is slightly different from that on the ZyWALL/USG FLEX/ATP series.
    We are checking on it, and I will keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Asgatlat,
    Hope it helps.
    Zyxel Melen
  • Asgatlat
    it works, thank you
