USG Flex 200 and Google Authenticator for vpn
When using manual configuration, the script will be generated automatically but won't be visible in the local GUI.
The script is only displayed once - specifically when using the VPN Wizard and immediately after completing the configuration process.
As for your other question, we've created a new post to better address it. Please continue that discussion in the new thread.
USG FLEX 200: is 2FA supposed to work on L2TP vpn? — Zyxel Community
Zyxel_Judy
>When using manual configuration, the script will be generated automatically but won't be visible in >the local GUI.
And it is reachable in other ways? ssh, ftp…
Or is it hidden forever?
Hi @valerio_vanni,
Please allow us to rephrase the explanation. The script can only be downloaded via the wizard. The manually configured VPN won't have a script to download. However, you can add this VPN configuration to the "Configuration Provisioning" for SecuExtender to get from the server/firewall.
In addition, you also can edit the script from the wizard to fit your VPN configuration.
Zyxel Melen0
- 241 Nebula Ideas
- 6.8K Security
- 761 USG FLEX H Series
- 382 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
