Cannot access settings of Zyxel nwa130be
I bought a new access point (Zyxel nwa130be) that is connected via DHCP to my router.
When first trying to login to the local web admin page via the IP address assigned by the router (not via cloud), I login using the default admin and password, but then I only see very basic configurations without being able to configure almost anything (except the IP connection type), and I am not prompted to change the admin password.
How can this be solved?
Hi @Samer985,
Please help to check if you can access this page on your side.
If you cannot find this page, please press the reset button for 10 seconds to factory default your AP.
Zyxel Melen0
Hi @Samer985,
Zyxel Melen0 -
I have the same problem. But the factory reset did not work. The interface keeps telling me that the device is managed by nebula cloud. But I deleted the device before and also my account. Any ideas?
Hi @spongetti,
It seems like you haven't removed the device from your organization, please reference this FAQ:
How to Remove Your Device from Nebula and Administer It Locally — Zyxel Community
Zyxel Melen0
- 441 Beta Program
- 294 Service & License
- 461 News and Release
