Cannot access settings of Zyxel nwa130be
I bought a new access point (Zyxel nwa130be) that is connected via DHCP to my router.
When first trying to login to the local web admin page via the IP address assigned by the router (not via cloud), I login using the default admin and password, but then I only see very basic configurations without being able to configure almost anything (except the IP connection type), and I am not prompted to change the admin password.
How can this be solved?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    edited July 2024 Answer ✓
    Hi @Samer985,
    Please help to check if you can access this page on your side.
    If you cannot find this page, please press the reset button for 10 seconds to factory default your AP.
    Zyxel Melen
