Authorize Link URL Address not working at all or correctly
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited June 2024 in USG FLEX H Series
USG FLEX 200H V1.20(ABWV.2)
A whole load of problems
Authorize Link URL Address by from interface LAN PC1 with SSL VPN on PC2 does not display the URL on PC1 by policy control rule to allow unless all policy control is disabled!
Authorize Link URL Address by from interface missing WAN interfaces
Authorize Link URL Address by user defined like zyxel-router7.ddns.net by HTTPS not using Server Certificate for zyxel-router7.ddns.net and uses default.
Even with policy control disabled for the Authorize Link URL Address for Google Authenticator code to enter in does not work only when setting up Google Authenticator for a user it says vailed but using it with the Authorize Link URL Address shows with Authentication Fail(invalid code)
