Any VPN related issue in 5.39(ABWC.1)?
I am running an USGFLEX100W and after upgrading to 5.39(ABWC.1), my dynamic IKEv2 IPSec VPN is not working anymore. I thought it might be some configuration change, so I went back 2 months (I have weekly backups), but it still don't work. It don't work on any of the mobiles it used to, and the laptop I used to connect is giving me a similar error. This is what I see in the firewall:
[SA] : No proposal chosen
[ID] : Tunnel [IPSec] Local IP mismatch
I am using a domain name, but this is set in the certificate, and the client is also set like this. It used to work normally.
The mobile log shows this:
[ENC] parsed IKE_AUTH response 1 [ N(AUTH_FAILED) ]
[IKE] received AUTHENTICATION_FAILED notify error
Any idea what could be wrong?
Is VPN Local Policy set to IP 0.0.0.0 ? give that a go
It turned out to be a faster resolution than I thought. A rookie issue apparently…
The certificate expired on 8th of November… Interesting though, that it drops local IP mismatch.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
