ikev2 remote vpn cannot connect to ZyXEl 200H recently
Hi, I was able to connect to the ZyXEl 200H via windows 11 vpn client using ikev2 vpn until this week. Out of the 10 computers using ikev2 vpn to connect remotely, only 3 computers are having similar problem. It connected and after a few second it disconnects. Now I cannot connect at all after I try resetting my vpn connected. One of the have a different type of error, indicating that there is a firewall blocking the connection. Before that it was working normally. Anyone have similar problem.
If the other PC's connect fine then it must be fine
I take it these PC are remote? what router do they have and have they rebooted?
its possible the Certificate got removed? delete VPN and set it up again
All the PC's are connected through their home internet connection. For one of the PC's which use Windows 11 Pro, I found that it had been updated to the latest update. So I revert the PC back to the previous update version, after that the VPN client for that PC is now working normally. So I think somehow the latest Windows 11 update affect the VPN client connection to Zyxel 200H. I have checked and none of the PC's have have their certificates removed. I will try again with the other 2 PC which uses Windows 11 Home and Windows 10. All were working normally for months before the problems start about 2 weeks again.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
