Virtual WAN
hesbynet
hesbynet Posts: 2 image  Freshman Member
edited April 2021 in Security
HI.
I have a problem. I gonna describe what I do:
I created a virtual interface and asigned a ip.
I make a nat 1:1 to some internar pc
I activate the icmp ping, for test the interface.
I make a policy control rule, and the source is a single ip.
when I pinging don't answer me.
I have the same configuration whit others virtual interfaces and working right.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @hesbynet
    Regarding to the setting your configured, the ping process should be worked.
    Can you try to disable the security policy or turn off the PC's firewall and check it again?
    Charlie
  • hesbynet
    I gonna try to deactivate the firewall of windows
