Missing CLI commands on XS1930-12HP
Hi
I am new to this forum. Have used an old zyxel switch before, but now I am back on zyxel again. Just bought an XS1930-12HP.
I have just installed it and done some test by configuring some VLAN trunks and other stuff. Seems to work as expected. Interesting that it takes 5-10% CPU when idling though…
I have bought and activated the access L3 license and therefor configured my VLAN stuff over the CLI (used cisco style "clv").
Now… I have upgraded to the latest firmware "V4.80(ABQF.4) | 08/23/2024". Now I am looking into the CLI guide "XS1930-12HP_V4.80-4.90_Ed1-CLI.pdf" where I can see there is commands for "sfp" and "slot".
There is simply no "show sfp" or "show slot" command in the switch, but there is in the CLI guide. No matter what mode and privilege I have… What am I missing?
Thanks in advance
//Peo
Hi @peos42
Thanks for your input. Please use the command "show interface transceiver XX" to display the SFP information. XX is the port number of your SFP port. We will edit the CLI reference guide since the command "show sfp" has not been used for some time.
The "show slot" command is for the stacking slot information. The CLI reference guide is for the "Ethernet Switch Series", but XS1930 doesn't support the stacking function, so you cannot use this command.
Zyxel Melen1
Hi @peos42
Zyxel Melen1 -
Ok. That explains it :)
Tnx för the quick reply @Zyxel_Melen
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
