block a bot
TedB
TedB Posts: 5 image  Freshman Member
How to block a bot on our USG-50 using Security Policy.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @TedB,
    The better way is to add some files to your server. Setting a security policy to block bot access might be a huge work.
    Zyxel Melen
  • electsystech
    electsystech Posts: 60 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    Is that a Flex 50? A USG 50 is a first gen router that was end of life years ago.
    Can you give more details? Is the bot attack on the wan interface?
  • TedB
    Understood, small budget on this end for our nonprofit. USG-50 not flex. I followed a couple examples of blocking websites but that has not blocked the bot activity. We get pounded by amazonbot. I have a server firewall, software, that stops access once inside the external appliance. I want to stop it at the wan level.
    I set up an Object Rule similar to GEO and a sister Security Policy so just need to tweak it.
    Thanks for response.
  • Zyxel_Melen
    Hi @TedB,
    Zyxel Melen
  • toiletspray
    toiletspray Posts: 1 image  Freshman Member
    edited December 2024
    @basketball stars You're right that adding files to the server, like a robots.txt or implementing CAPTCHA challenges, can be effective for managing bots, especially those respecting web conventions. However, for malicious or persistent bots that ignore these measures, setting up a security policy on the USG-50 is more robust.
    Thiers no way to stop this really when a bot goes to example.com and loads the index page it then can look at the other links and loads them.
    But if you didn't have a index page then when it goes to example.com it can't load anything only if you know the page like example.com/homepage.html will it load
    also disable directory listing on server
