GS1900 V2.90(*.0) Firmware DNS not registering IP address issue
ASGR
ASGR Posts: 4  Freshman Member
Hello Community / Tech Support…
I have some GS1900-8 and a GS1900-10HP.
I recently installed the firmware update V2.90(*.0) for both switches but the SNTP server fails to update the time stating that I'm having DNS issues. On checking SYSTEM→IP→DNS 1 is set to 0.0.0.0!
I reverted to the previous firmware V2.80(*.1) all addresses are registered as expected. It may seem insignificant but all the logs will have the wrong time.
I'll revert back to V2.80(*.1) for now until advised otherwise.
Regards,
A.
  • Zyxel_Judy
    Zyxel_Judy Posts: 1,731  Zyxel Employee
    Hi @ASGR ,
    Thank you for your feedback. We have confirmed this issue and developed a solution. Please check your Community inbox for the details.
  • Zyxel_Judy
    Hi @ASGR ,
  • TiggerLAS
    TiggerLAS Posts: 67  Ally Member
    First Comment First Answer Fifth Anniversary
    I can confirm this behavior on both the GS1900-8HP (Serial number starting S1), and the GS1900-16.
    Rolled back to previous firmware for the time being.
  • MSprecher
    MSprecher Posts: 2  Freshman Member
    Could you please send me the solution for GS1900-8HP and GS1900-8 as well?
  • coderjoe
    coderjoe Posts: 13  Freshman Member
    I am seeing this on all of my GS1900 series switches with serial numbers starting with S2.
    Could I also get the fix? Most important for my deployments are the GS1900-8, GS-1900-8HP, and GS1900-24E.
    Alternatively I can wait for an official firmware update if I can get an ETA on when this will be fixed.
    We are very excited about the ECDSA cert upload support.
  • Zyxel_Judy
    Hi @MSprecher , @coderjoe ,
    The date code firmware have been sent to your Community inbox. Please check and download them.
  • Zyxel_Judy
    Hi @TiggerLAS ,
    Please let us know if you need firmware version 2.90P0, which includes the solution for the NTP issue.
  • MSprecher
    Worked perfectly. NTP-problem solved on GS1900-8 and on GS1900-8HP.
    Thank you very much!
    Matthias
  • aZuL2001
    aZuL2001 Posts: 4  Freshman Member
    Where can i find that firmware?
    Have the same issue :(
  • aZuL2001
    Same issue on a S162L4400…. serial number GS1900-8HP, rev B1
