Is it possible to show fiber optics info on XS1930-12HP?
peos42
peos42 Posts: 38 image  Freshman Member
I have an old Netgear prosafe switch. On it I can run…
Is it possible to in some way show such info on this XS1930-12HP if moving these SFP+ units fromt the netgear to the zyxel switch? I have Access L3 license.
Thanks in advance
//Peo
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @peos42,
    Have you tried the command "show interface transceiver XX" I mentioned in another post? Below is the example result of the command:
    Hope it helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @peos42,
    Hope it helps.
    Zyxel Melen
  • peos42
    I had not yet tested a real SFP+ when posting here… Just looked for the equivalent commands in the cli and the cli PDF… Sorry for that. Now I have added one physical fiber optics and one 10GbaseT SFP+, and indeed I see the info I am looking for with the "show interfaces transceiver NN"
    Tnx and sorry for not trying that out before posting :)
    Peo
  • Zyxel_Melen
    Hi @peos42,
    It's okay to ask before you test. 🤗
    Zyxel Melen
