How to configure USG FLex 100 to allow clients to use outbound NordVPN?
You can't get should VPN to work with USG
BTW. If I allow all outbound traffic then the VPN works. But I want to be more surgical on what ports to open.
I read your post wrong was thinking you wanted to run the VPN on USG
not sure what ports are needed for NordVPN but likely not inbound
it depends on the protocol used so might be UDP 500 and 4500 with protocol 50 (but unlikely if behind NAT)
or NordVPN goes by TCP or UDP on random ports so check with Wireshark you might be able to do a wildcard fqdn and allow it that way
thanks. Yes, it works with no inbound ports.
What I have seen form the USG log is that it even uses ports in the 50000 range. For example 51820. This seems strange for a VPN?
In fact if I open udp 51820, VPN connects. But I feel this is random
If you can do this
The ports will be more fixed
the following port for OpenVPN
OpenVPN connection on NordVPN – Live Chat, VPN Setup, Troubleshooting | NordVPN Customer Support
I had 1194 and 443 already open. But only opening 51920 made it connect
As long as its not random or tell the client to be random then ok
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
