Virtual WAN
HI.
I have a problem. I gonna describe what I do:
I created a virtual interface and asigned a ip.
I make a nat 1:1 to some internar pc
I activate the icmp ping, for test the interface.
I make a policy control rule, and the source is a single ip.
when I pinging don't answer me.
I have the same configuration whit others virtual interfaces and working right.
@hesbynet
Regarding to the setting your configured, the ping process should be worked.
Can you try to disable the security policy or turn off the PC's firewall and check it again?
Charlie0 -
I gonna try to deactivate the firewall of windows0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
