XGS1250-12 After upgrading to las firmware 2,5GB ports don't work at all
hetosu
hetosu Posts: 4  Freshman Member
I've upgraded to the last firmware my Zyxel XGS1250-12 (XGS1250-12_V2.00(ABWE.0)C0.bix) and after doing that and reboot normally, all the ports 2,5 GB don't work at all.
Does anyone know how can I solve this? Thanks!
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @hetosu,
    Since this is a layer 1 issue, could you help with some cross-tests to clarify? You might need to isolate the switch before cross-testing.
    1. What are your symptoms? The multi-giga ports cannot link up or cannot link at 2.5 GB?
    2. Connect two switch multi-giga ports as a loop to see if it can link up at multi-giga speed or 1G.
    3. Connect other 2.5G devices to the multi-giga port to check if it can link up.
    4. Find a new cable to connect and clarify.
    Thanks.
    Zyxel Melen
  • hetosu
    Hi Melen,
    I answer between the lines:
      1. Answer: cannot link up at all
      1. Answer: No signal with even with new cable
      1. Answer: Same result: no link up, no lights
    Kind regards
  • Zyxel_Melen
    Hi @hetosu,
    Thanks for the detailed information. From your information, it is more likely that the XGS1250 has a hardware issue.
    Could you share:
    1. Which firmware version did you upgrade from?
    2. What serial number is our XGS1250?
    Zyxel Melen
  • hetosu
    edited December 2024
    Firmware:
    The last: XGS1250-12_V2.00(ABWE.0)C0.bix
    The previous: XGS1250-12_V1.00(ABWE.3)C0 or XGS1250-12_002.351-01-01170 (I'm not sure)
    SN: D8ECE57DB9DC or S212L46003509
    kind regards,
    Héctor
  • hetosu
  • Zyxel_Melen
    Hi @hetosu,
    Thanks for the update.
    Please help submit the RMA request since this is a hardware issue. You may reference this post to submit it.
    https://support.zyxel.eu/hc/en-us/articles/360002463234-How-do-I-claim-warranty-service-for-my-Zyxel-product-RMA-Process-
    Zyxel Melen
