EEE / Green Ethernet
Thank you! When using them for Dante (audio over IP) this is crucial to have switched off.
Hi @jensskov
If you require audio over IP, I’d recommend considering a switch model specifically designed for Networked AV scenarios. While your current GS1915 supports IGMP snooping well, the models listed here
are tailored for Networked AV use and offer advanced features optimized for this purpose.Kay
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
