connection of two remote subnets through the main router
Alex_ll
Alex_ll Posts: 1 image  Freshman Member
edited December 2024 in Security
how to set up routing so that PCs from .3.1 are visible from the .2.1 subnet ?
I have 2 usg20-vpn and one USG Flex200
  • Zyxel_Kay
    Hi @Alex_ll
    Could you please clarify which VPN type you are using for the connection? Specifically, are you using a site-to-site VPN or a hub-and-spoke VPN configuration?
    Kay
